Specific Mobility
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=47127
Author:  Tom West [ Sat Jan 23, 2016 10:35 am ]
Post subject:  Specific Mobility
I'm having a struggle getting a handle on Specific Mobility. Working from page 1-89 in the Gore book. I think the weight for deflection is in newtons. Given that and given made up numbers I have tried to work through the formula and am not sure if I'm even in the ballpark.
Using 400 grams (4 newtons) and a deflection of .1mm the stiffness is 40. (units?)
Plugging this into the formula for mass and assuming a f of 185 it works out to .0000296 (units?)
Doing the Specific Mobility it comes out to 29.
Wonder if any one can work the numbers and tell me if this is right or wrong.
If anyone has any numbers from their own work they would be very much appreciated.
Tom
Author:  Ken Lewis [ Sat Jan 23, 2016 11:40 am ]
Post subject:  Re: Specific Mobility
Yep. The numbers work Tom. On the high end of the Specific Mobility scale.
Ken
Author:  Tom West [ Sat Jan 23, 2016 11:54 am ]
Ken: Thanks, that what I wanted to know. Just made up data and quite obvious I would not be any where near this with true figures.
Tom
Author:  Ken Lewis [ Sat Jan 23, 2016 12:23 pm ]
I use a one and two lb. dumbbell in a setup similar to the one Jeff H. posted in your other thread. My dial indicator is in inches so I set up my spreadsheet to convert to metric and then do the calcs. The numbers on a recent build were something like this:
Load...1lb. --.448kg which excel rounded to 4.3n
Deflection... .0028 in. or 7.1x10^-5m (.071mm)
f with sound hole closed....167hz
The resultant specific mobility worked out to be 16.9 s/kgx10^-3
I like to measure bridge rotation as well when doing the SM measurements
I'll also use a 2lb. load to verify that the results double.
Ken
Author:  Tom West [ Sat Jan 23, 2016 1:43 pm ]
Ken: Thanks for the numbers. Looks like your guitar is up there with the big boys.....Congrats and thanks again.
Tom
Author:  Ken Lewis [ Sat Jan 23, 2016 2:40 pm ]
Yeah Tom that guitar is quite responsive, loud and plays very nicely with bare fingers. Not one for a raucous
kitchen party though. The numbers by themselves don't tell all. The trick, I think, is to let the numbers be an
indicator to help steer you where you wanna go. I think building technique and skill/craftsmanship play a huge roll.
I think someday I will build the perfect guitar.
I also think, that because I think that way, that day will never come. :lol:
Ken
Author:  George L [ Sat Jan 23, 2016 9:03 pm ]
I think that that way too ... I think. idunno
